Tree shear on 2.7t machines
10 minutes ago, Rwhiteheadfirewood said:
The only thing I noticed with that machine is you have no control of the tree / branch once it's cut, or do you?? Rob
It’s a fine balance between ‘wanting’ to hold the cut tree/limb or not.
On a smaller, narrow wheelbase machine, I prefer NOT to transfer the lever force of cut piece onto machine due to potential to turn it on it’s side.
Also, a cut and hold head (on a smaller machine) is less likely to have rotator function so you can only cut and hold relatively upright stems.
The cut and release function allows for a good degree of directional felling through the rotator plus, important for me, elevated cuts that are at any angle rather than just vertical.
I looked long and hard at the cut and hold but dismissed it (on this small machine) because of the limitations above.
You can still grab and move cut pieces with this style.
Really depends what your primary use will be - if it’s all upright stem cuts, maybe cut and hold is best, if variable height and angle cuts (like hedge reductions) worth considering cut and let go.
I made up a grab that fitted the quick hitch on our 2.7 ton machine. It worked in the same plane as the tree shears but without the shear, we used it in conjunction with cutters to pull regen of about 6" + diameter trees off of step cuts. Dont think I would want to hold and slew with anything much bigger on that size machine and that was with an attachment considerably lighter than a shear.You definitely need to plan what you are doing and where you are laying it down, once you start chasing the timber to the floor you are committed, there is no standing it back up. 13 + ton machines are a different ball game.
Bob
Bob
Yea you have to plan your work, and understand the machine capabilities, it’s no where near a larger set up but you can tow it to site
