Cut the top off just above the railings.
Make vertical bore cuts down the pith with a big bar. Remove crud.
Bore cut a square hole from side. Remove wood.
Fill with kindling and light.
When going well, add coal down the top.
[emoji106]
1 hour ago, Gerardo Sanchez said:
There is a school.
I just wondered about access, but if you are happy to leave the stump its of no consequence. It would be interesting to give it a bit of a tug, just to see what moves. (Probably the shed).
If I were tackling that, I might consider moving/removing the shed first, to "let the dog see the rabbit", then probably move the founds and shed back tight up against the fenceline afterwards.
Figuring if you stay really low with the chainsaw you should be below the nail-line, but obviously need to carefully clean the bark and soil/stones away first(with a pressure washer perhaps?).
The sort of job I relish as a challenge, BUT without the pressure of time or needing to turn a profit on the job.
Marcus
