Mower engine needs fuel pump button pressing
cryptogram
Lurkalot, I think there's more to it than that. When I first tried to start it this spring, the priming button would not pull fuel up. I had to take it apart an put fuel into the carb itself. When it eventually started I needed to pump the primer every few seconds and then it ran alright. And that's the position now. Is there a diaphragm that now has a hole in it?
Old fuel eats away at the diaphragms. Not a hole necessarily but could be brittle. I’d stick a new carb on.
Exactly why I'm saying the carb needs proper cleaning.  Did you leave any fuel in it from last season?   As I'm not 100% sure what carb you have on there, posting a pic would help.  I doubt it has a diaphragm though.   Usually primer on one of these would just push air into the float bowl, and that induced pressure pushes a small amount of fuel up the main jet for starting.   It's running far too lean which is why you have to keep priming until it warms up.   Cold engine needs more fuel to run than a warm one.
Edited by lurkalot
missed a bit.
Yes, you're probably right. Question is, which one to get. All the ones I've seen have been for a Subaru engine powering a pressure washer. None for mowers. Now, they may be the same and I don't see why they shouldn't be, But are they? I've asked the eBay sellers and basically they say 'sorry mate, look at the picture'.
Remove the bowl and then main jet/emulsion tube, clean it “thoroughly” (and i say thoroughly cos had to do it twice on my honda/bomag whacker plate) what sometimes appears clean really isn’t clean enough. Ensure all gaskets etc are in tact too, clean and check as you go, preparation/cleanliness is the key.
