18 hours ago, aspenarb said:
If its only a few bits and pieces have a look at wet blasting, its a syphon that takes in kiln dried sand and adds it to the pressure washer lance. Really effective and no dust to breathe, decant the sand into a clean and dry 20ltr container which will keep the sand dry and away you go.
WWW.EBAY.CO.UK
1 K A dapter For Karcher. Transparent sandblasting tube, sandstone made of diamond sand. Sandblasting Tube L...
Bob
https://i.ebayimg.com/images/g/WjUAAOSwA9temaTA/s-l1600.jpg
I gave my mate a ton of grit to use with one of these kits, he said it was really slow and used loads of the grit to do one small panel. Couldn't reuse the grit again either. Did you find it quite slow Bob?
8 minutes ago, doobin said:
Any sandblasting is slow without a big old diesel compressor.
Can sandblast a decent speed with my setup,Sandblasted an old oak door down in 15 minutes, 5 square metres in area
I’ve got two 3hp compressors linked together, it’s ok but I wouldn’t want to do too much.
Yes but what type of pot/gun blaster are you using,The flow rate on 2 linked compressors will be the same as 1 because both rated at 3 hp so regulator will control the pressure. Only thing it will do is give a longer running time before motors kick in,Would need a bigger hp compressor for bigger CFM
Edited by topchippyles
That's a decent speed right enough ?. Were you blasting old paint off the door?
Yes hard coated varnish from a 30 year old door so god knows how many times it was done
Yes looks a slightly more expensive 1 was it top chips??
Around the 150- 200 mark?
The 1s at 40 quid just look like a paint gun really.
Don't mind spending £200 if it will definitely work, still intend to use grinders for flat surfaces etc
No looked yesterday and around the 70 ish mark, Link below and look at the reviews,It has 3 nozzles so work from the smallest up and see how your compressor runs with them,I just use the biggest as runs great but a smaller compressor may need a smaller nozzle,3 sizes included
Clarke CSB10 Siphon Feed Sandblaster
000510117
5 reviews
Powerful siphon feed sandblasting kit for greater control and efficiency. Quickly removes paint, surface rust, dirt/grease, burs etc. Mobile tank features two large rubber wheels and handle for easy manoeuvrability...
£71.98INC
VAT
Compare (max 4)
