I’m trying to get away from hiring in light stations / towers for night work on trees. Does anyone have experience of light bars (mounted on the front of vehicles; Ford Transit Tipper in my case) capable of lighting up large trees for Arb work? It seems to me there are three types: spot, flood and combo. There’s massive variability in prices even for similar spec units. Can anyone give recommendations? The photo I’ve attached seems to be a good one but never had experience using them as never needed to.
Unless you mounted it at the top of a tower, would be no good for working infront of, it will blind you and create big shadows.
Maybe buy a 2nd hand lighting tower? Look a lot of good ones on ebay for a grand, probably little deprecation in them if you needed to sell it on in a years time
I've got 26" spot/flood combo eBay specials on both my tractor and mini-digger. With the tractor, been perfectly lit for running around fields (I have a couple of small 6" ones on the rear as well for reversing/PTO stuff) and using as a mobile lighting rig. I don't bother with the headlights that actually came on the tractor! With the digger, its fine for digging at night - was doing foundations and loading a dumper, though I might get an offset spot to shine off the boom.
I've seen the same sort of lights, CE marked and "UK supplied" from traders/websites but at 10x the cost. There's a lot of snake oil seemingly involved but the cheap eBay ones work perfectly well. Someone would really have to prove the extra value of a multi hundred pound one over a similar £40 eBay version.
