Husqvarna 61 on big oak optimal bar length and chain
 I just cut to heat mine and friends' houses, and for timber for my craft. I presently have a solid nose 30" bar on a decent running 051 and a couple of 50cc saws running roughly 16" blades, a 31 and a Mak 5121. I doubt either of those to can pull a bigger bar through oak. I've bought a black top 61 powerhead to learn on. I've checked the bore and piston and am getting a carb kit as it won't run on the hi jet. If I sort that, what bar and chain is this likely to pull? I assume that this is a high torque motor rather than a fast cutter as specs say up to a 24"  bar, so a firewood saw. I know I can put a bigger jug on it but it seems in good condition as is.
  A massive oak has come down on the estate, well over 4' across, and I've got the stem and branches  that   a friend's 16" bar can't deal with. What do experienced loggers think  the best bar combo  would be for me?
Edited by cloggy
Best size bar for husky 61 is an 18"' saw will be well balanced and not slowed up.
Best of all is a 15'' with 9 toothed drive sprocket.
3/8 chain is best.
I agree 18" would be best, a 20 absolute maximum, turn oil pump to maximum, check AV rubbers as they will be quite soft or broken on an old saw, there is a hard version AV rubber if you use longer bars, the vibration however will increase with these rubbers.
Your 051 has the capacity already, nearly 90cc and 30" bar.
