9 minutes ago, Lazurus said:
Coving cutter, router and a template?
:dito:
Alternatively you could carve them leaving tool marks like in the bowl below
Edited by Woodworks
33 minutes ago, Stere said:
Thanks
One of theese you mean?
TITMAN.CO.UK
A comprehensive range of guttering/cove mould cutters all with plunge facility and an upward shear.
Only thing google found without bearing @ bottom.
I always liked the CMT range of cutters
WWW.MACHINERY4WOOD.CO.UK
CMT Round Nose Router BitsPersonalise your doors drawer fronts, panels or any surface you choose with your own...
Be aware that it's very easy to leave burn marks on this sort of work. A variable speed heavy duty router would be best running at low speed. Get near to final depth and make very light but relatively swift final pass. A bit of practice on some spare wood of the same species will prove invaluable. Keep the cutter moving with no pausing but it's all easier said than done though.
