Hi guys Happy New Year,just a quick reminder I am still looking for some sort of 3 phase power being either a converter or a generator.
 Thanks Mark
  • 3 weeks later...
Hi, first post, been looking for years but didn't seem to have anything to offer, and now this post is trying to sell you something.
I have a Brook 240V single phase 50Hz 11kW motor I am not going to use. Comes with the all important split phase start and run capacitors, interlocked contactors and timer. It is 1450 rpm, full load 51A, locked rotor current 200% so very low for starting, locked rotor torque 50%. This motor is heavy! About 120kg, be warned.
I have had a wood for near 20 years, and was going to buy a Lucas saw mill until their prices near doubled from one APF show to the one two years later. At that point I decided to make my own sawmill, I had a single phase 20kVA genset hence the motor. Also picked up a set of band wheels etc, 20" diameter so will give 7500 ft/min at motor speed.
Plans have changed, bought a Logosol Farmer's mill with the bandsaw attachment. I want to do all sawing as quarter sawn, and this will work up to the largest trees I have, 60cm dbh. I have made my own phase converter to run the 6.4kW bandsaw motor.
If it stops raining might actually be able to try it out.
That motor is like my mates todger 12 inches on the slack ?   A BEAST
Edited by topchippyles
