4 hours ago, tonytree said:
I’ve got the mk 1 husky t540. While I really like the saw, apart from needing choke if not used for 5 minutes.
I think the stihl 201 is a little bit better (not by massive amounts), but if you go for the stihl or husky I don’t think you’d be disappointed with either.
The MK2 t540 has the " fragile " bits beefed up and a different flywheel ( ignition timing I think )  I have a MK1 with all the bits of a MK2 fitted except for the flywheel .
