4 minutes ago, Justme said:
I can do 25m3 per day with one person helping & good wood.
What processor is that out of interest?
Edited by carpenter1
Just now, trigger_andy said:
Sure, but that must be constant processing with little breaks and you get jams etc.
I'm not sure how big the processor is but that's not a huge amount I wouldn't say. If I have someone loading I aim to do 5-10cube an hour (with a large processor) depending on the wood and cut length. Obviously you lose a bit of time to issues but after you get used to a processing you shouldn't have many blockages and a chain should last half a day.
51 minutes ago, trigger_andy said:
You must be farked after that?
Actually not.
The processor loads it so you dont handle the wood that much.
Yes its a good days work but not killing yourself if you set up is right.
Stop for two or three tea breaks dep on re fueling/ chain swap / sharpen needs  & a lunch break.
Yep bigger sited processor will do loads more.
This is a little 750kg road tow WP30.
Peak rate is 3 to 4 m3 per hour but stoppages reduce the rate over the day.
Not bad at all. Maybe its because when I process Ive been lumbered with the gnarly hardwood. :D I see theres a stack of poker straight birch waiting for me when I have time, that will be a dream come true. :D
