Piece of string answer.
Hard or softwoods?
Forest grown?
Artic load or trailer?
Graded?
Delivered?
As a vague rule £100 a ton is a fair price for most hardwoods collected.
Less for softwoods.
Valuable species can go for a lot lot more.
[emoji106]
3 hours ago, Phil G 2217 said:
Can enyone tell me what would I be expected to pay for logs or a log for milling
As i am thinking of buying  a sawmill . Maximum diameter  30in lets say about 12ft long.
I think it would be beneficial for your research to offer a lot more detail as to what you expect to be doing with your sawmill. At the moment, your question is so vague you might as well be asking "what should I be expecting to pay for a car?"
Here's some examples of milling logs I've bought recently.
Beech 20-30" x 8' £65 a ton collected from the forest.
Sycamore 3'x 8' superb character £100 collected from field.
Elm 4' x 9' delivered £300
Oak 2-3' x 8' collected from forest £100 a ton.
Sitka 2 ton for £120 delivered.
Prices will vary quite a bit depending who you know,
How far away?
What's the accesss?
Can you collect big heavy logs?
A 30" oak log at 12' weighs about 2.5+ tons.
And turning big logs on a mill is very difficult.
(As I found out [emoji23])
[emoji106]
How far away?
What's the accesss?
(As I found out emoji23.png)
Quite  expensive  you wouldn't get much then .
Depending on size two or three logs . I do have permission in some woods but only trees that have fallen  through bad whether.  I'm  in Doncaster area were would i start to look. Thanks for your info
Put a "milling logs wanted" advert up.
If you can collect from Huddersfield, I've got a few logs I could spare [emoji106]
