Noticed this from last month's tree inspections, pollarded and felled several English Oak North London , in this section. Fine bore holes @1mm dia. Very active and fine dry sawdust.
20 hours ago, Khriss said:
Bore holes @1mm dia. 20mm to 30m depth. K
pinhole oak borer Platypus cylindrus I expect. They do get into the heartwood if the wood stays moist, in the second season. It was almost unheard of pre 1987 but has remained widespread since.
13 hours ago, AJStrees said:
Were these already dead oaks? Interesting if not as the pinhole borer normally goes for dead wood I believe. Or else severely stressed or dying trees.
Summer felled / pollarded 500mm+ dbh two yrs ago.. So not holding out much hope. Will turn into bat / raptor habitat poles with a forstner bit n cordless drill when I get round again. K
