Has anyone got the bigger Husqvarna battery strimmer? 520iRX
What's it like, is it any good for tougher stuff or is it more for edging?
What size of petrol machine would it compare to?
Suppose you need to know the power output in Kw of the electric motor to compare it too petrol annoying they don't advertize that in the spec probably because its fairly low under 1kw?
8 minutes ago, Mark_Skyland said:
The 20 in 520 means the machine has the power of a 20cc petrol machine, or there abouts.
Have you ever used one?
I'd looked on your site previously, does the Husqvarna pages need updating, different model numbers from the catalogue?
Makes it sounds rubbish 20cc
If the numbering system is correct the chainsaw  535i must have  a considerably better motor with more power?
Sorry no, only used the battery chainsaws.
Our site really needs updating in regards to the battery equipment, unfortunately Husqvarna thinks that it is a good idea to keep changing model and part numbers on a yearly basis to confuse and annoy not only dealers but end users too!
E.g, the top handle T535i XP is exactly the same as last years model the T536LiXP.
Its really hard to find any info on  power output of battery tools but any maker making it hard/impossible to compare them with petrol versions.
E.g Echo cordless strimmer:
WWW.MOWERSPLUS.CO.UK
Echo DSRM-300 Battery powered solid drive trimmer, convenient and easy to use.
No idea how powerful it is but its marketed a a professional tool.....
I think its kind of dishonest....
And cheap in USA:
WWW.STRINGTRIMMERSDIRECT.COM
Buy Shindaiwa T3000 Direct. Free Shipping. Check the Shindaiwa (by Echo) T3000 (14-Inch) 56-Volt Lithium-Ion...
Edited by Stere
Dunno what they're saying, but I assume they're trying to show the battery motor (on the left) has more torque than the 25cc 2 stroke
I've got the previous incarnation 536LiRX & would use it in preference to a petrol machine any day. Keeps down weeds around the paddocks, mainly with the metal blade, deals with nettles, bracken, brambles etc just as well as my old noisy smelly 2t. Obviously not got the power of a larger petrol machine but benefits of low vibration, noise, fumes & running costs are a big plus for me.  All depends what you want it for.
Sounds good more like a 30cc plus  machine in performance?
What battery model  did you get with & how long does it last?
Trying to find info online the Kw of the motor of the husky  but cannot.
The makita  cordless model  DUX60Z (combi power head)  is 600w output.
Edited by Stere
