i have a petzle grab that is apparently illegal because itthas no bolt just a spring clip holding it in!! never failed tho ever and ive had it for nrly 3 years!!!! i find the lrage grabs a pain because they dont always grab!!!!!!! and a 3m ne wire core, never let me down
  • Replies 38
I like the cores with two connection either end. I want one that is the best its simple when i ask for any gear at the shop whats the best im only interested it top gear my lifes worth it.
I know were all the same the best the money you have can buy.
So common guys whats the best safest easy to use nice grab secure :top:
I have a yale 3m wire core flipline with an ISC micro-grab on it. It's bloomin' marvellous - the snaphook is super easy to quickly attach and the micro-grab works fine on it too.
i use one from treeworker with a art swivel positioner have used most others and this seems best but not the cheapest way of doing things
If you're not often in conifers or other pitchy/sappy trees I think a friction hitch with tender makes the best lanyard adjustment there is. Easy one handed adjustment in both directions.
Hey im in need of a wire core complete kit wire hook and grab can any one offr the best ones there reviews of what they use thanks. :wave:
I use a Komet one £104 from georgecarr.co.uk i find it so easy to use, might be worth a look.:heeeelllllooooo:
I us ethe skinny red komet one with a snaqphook and an isc micro grab, used to use the thicker blue/white one but the komet is way better.
If you're not sure go for a grab over a prussic, grabs are much better at dealing with sap; dismantle a big sitka and a prussik will just stop working. Also a snap is much easier to use than a karibiner although technically its only 2 way locking.
