5 minutes ago, trigger_andy said:
Yip, torqued to the correct setting. Its an idicator on the B751, you turn the handle till the thrust washed meets a marked setting. Spoke to Logosol today, they said take the handle another half turn after this and maybe a little more and see if that helps. Do you get any waveyness when cutting through knots in your 130?
Nothing what so ever if there is a good blade fitted,You do as the blades get blunt but thats hrs of cutting from new.Sounds like its a tension problem to me.
May be worth posting on a different forum perhaps                                                             https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=2ahUKEwj6mIb_l4_kAhUsSxUIHfjaBaIQFjAAegQIARAB&url=https%3A%2F%2Fwww.arboristsite.com%2Fcommunity%2F&usg=AOvVaw3rTYz4XxGxmLNYVzAYcXiH
Edited by topchippyles
28 minutes ago, topchippyles said:
No need as its water cooled
The saw band is water cooled?
Some still add an additive to the water.
On some timbers it makes a big difference.
Not on the saws i have set up but not one to argue if it helps.
Try it on resinous woods.
Some even use red.
3 hours ago, topchippyles said:
Ive been on there quote a few times lurning but very little on the B751.
