This tree is @15 years old. (It was part of the property when I purchased.)  I noticed top thinning this year.
I'm considering having an arborist to come in an air spade to correct the problem.  I have consulted with two arborists', one says it can be saved, the other is saying, maybe not.
Thank you in advance for any feed back.
Edited by tedantle
description
Its a young tree. I feel its better starting afresh than  trying to save a tree that would need a staged root pruning regime over time, that may not work in the long run
Thank you again Paul
Is the tree showing signs of die back in the upper crown ? It’s all well and good posting pictures of roots but if the crown is healthy I would leave it alone ! Any extreme girdling I’ve seen has usually resulted in die back in a part of the crown ,that can be removed and balanced out according..Personally if it was mine I would plant another and wait and see if this actually dies back significantly and needs replacing ... Norway’s grow fast and in the grand scheme of trees imo are a relatively short lived species anyway but cutting through any of those roots you are opening up a whole new can of worms !
