Timberwolf 190
wrekin tree care
Best thing to do is strip it down then order what you need there is a lot of TW parts stockists in the uk you will have the parts the next day and if you decide to replace the main bearings loosen all the bolts whilst on the machine or you won't get them out when it's off the main one in the middle sometimes need a little heat.. Hope this helps
As above the plastic bushes are worth changing, also worth checking the stub shafts that run in the bushes are not knobbed, roller body grease hole that runs through the middle of the rollers is normally blocked solid so worth clearing that, check the splines for wear on the hydraulic motors and the ones in the hub bolted in the roller, while its apart its worth having the roller blades sharpened. Other than springs I cant think of anything else worth worrying about in the rollerbox department.
Bob
