Hi, just a few pics of me removing a big poplar. Diameter on the stump 1.1 m. It could not be felled in one piece because it would have fallen in a Willow in the garden. Took it down in about 4 hours, and an additional 2 hours sawing logs.
Could leave all the wood there, the owner will split and chip everything. :confused1:He also made the pics.:thumbup1:
Pascal
Good luck cutting that head out of the ground!
Big tree Pascal.
Nice one.:thumbup1:
After the biggest logs were sawed, the owner and his neighbour digged it out.
Showing off their skills !!! :001_tt2:
P.
Nice pics sideleaner, could you explain what i'm looking at in picture 2 like what do you use the wolf pole for setting lines? The 2 lines, they climbing lines if so what system you using?
Marc, I use the wolf pole with a hook to attach the rigging rope to the end of the branches. I had to rig down small pieces on one side of the tree, because there was a gardenhouse of the neighbours underneath.
I use a hithclimber on the high tie-in point and a second rope with a simple prussic to go out far on the branches.
The other thing you see next to the pole (picture taken against the light :sneaky2:) is my drinking bottle, I like Aquarius ! :001_tt2:
Pascal
Thanks Pascal
I need to get my self one of the wolf poles some day nice and light and cheap in comparisson to Silky stuff it would make some rigging situation a little easier, also like the look of the telescopic pole Sherrills sells just never heard of someone using them.
