i want an art rope guide please :)
alex_m
  • Replies 37
Yes, nearly. You don't need to do one as good as drews. You don't have to splice anything either. All you want is a pulley up the tree to run your rope through. That can be done very cheaply i.e the cost of the pulley only, and any rated pulley will do. The petzl fixe would work fine. Tie it onto a prussik loop, then tie the prussik on another bit of ropewith a big bowline at one end with hose pipe on it to keep it open. Then you need a retriever on the other end.
HAve you got any spare pulleys already?
