First attempt head cam!
Rupe
Ok. First the excuses........
what a rubbish tree to climb, wobbly, prickly old acacia. Job to shorten one large limb and remove another plus a bit of deadwood. Batteries ran out half way through, I guess I should move faster!!!!!
Anyway, nothing of any interest just testing the new headcam. A couple of good one handers and a rope switch at the end but some pretty poor climbing!
[ame=http://www.youtube.com/watch?v=qQ2qzzVeKnY]YouTube - acacia.wmv[/ame]
  • Replies 62
Yep, same as Steve's. Mic seensitivity is Hi so I guess thats as good as it gets unless something is wrong with it. If I ever made a video I guess I would put a soundtrack on it.
Quality does seem ok when viewed on here. ANy larger and its not so good. Battery life seems to be a problem though.
Half an hour!!!!!!!!!!! On standby most of that time too....
Have just found a settign that turns off the LCD screen whilst in use, thats good cos if its on yer head then you don't need the screen on. That should save the batteries a bit.
No. Works with any set up. The marlin spike knot is to stop the system self closing which probably wouldn't happen with a prussik knot. i.e. the if friction hitch gets snagged or touches a branch, then as you pull you would advance the hitch up the rope making the sytem shorter and it won't come back to you. A prussike is less liekly to do this but a marlin knot is still advisable. (I should have set the knot better as it came back to me in a bit of a mess)
