3 hours ago, Johnherbert said:
Any recommendations for a mulcher attachment for a mini skid steer ?
Twelve years ago I used an FAE which seemed okay for the job, just about managed 6" standing trees but it was on a 100hp skid steer with high flow hydraulics
As the man said. Check for flow rates and carrying capacity. No flow - no go! Also, you may need to be sure that your engine has enough cooling capacity to run flat out with choked radiators as mulching is a right dusty job. That goes for driver protection and cooling too. Some people spec up the carrier on purchase to do the job that they want rather than acquire the unit hoping to find a flail that might fit/work. Good luck going forwards. Are you mulching or flailing - they are different.
