FUEL gauge Greenmech 150p
Shaunpaul
17 hours ago, Shaunpaul said:
Any idea why fuel gauge reads empty despite being full? Was fine until today. Works fine when removed from tank and manually move float up and down.
@Jase hutch
also what size socket & Allen key is needed to change blades?
thanks
Hi Shaunpaul, I will look into the fuel gauge issue , I'm not aware of a problem.
The Allen key required is 10mm..
Jase.
12 hours ago, PeteB said:
Sorry Shaun, had your email but got stuck doing other stuff. The float is sticking somehow. I am stuck for an answer just now but Jase and I will get something organized.
Hi Pete, removed the whole gauge. Full  tank of fuel in, when I hold the float up to the top and insert the system into the tank as far as possible, then drop the float.....is sinks to the bottom again and reads empty. Can’t see any holes in the float and there’s no fuel in the float. Its a strange one ?
