Yep, definitely go to Copford Sawmill with that. You stand to lose hundreds and hundreds of pounds (maybe close to £1000) to sawdust if you chainsaw mill it.
Much easier to get someone else to mill it for you and a bandmill like a WM1000 is literally effortless to use, as opposed to pushing/winching a double ended set up though burr elm.
Andy - the blades on a mill like a WM1000 are actually quite cheap as they are only 50mm wide.
6 minutes ago, smoothjack said:
14 minutes ago, smoothjack said:
28 minutes ago, Rough Hewn said:
I chainsaw mill professionally all over the uk. Big J is absolutely right.
Don't turn that incredible tree into sawdust!!!
It won’t be I promise ??
