Hi all,
I’m looking to start up my own tree surgery business probably next year and I’m just after a bit of advice.
1 - I’ve got experience with a saw but want to do the relevant courses for climbing and using a saw up a tree. What specific courses should I look at and are there any others I should do?
2 - Do I get a chipper? I’ve potentially got somewhere I could keep it but do I just hire one when I need it?
3 - What vehicle, pickup tipper or van tipper? A pickup would be more suitable for parking at home and I’d need it to be my everyday car. How much more can you fit in a van tipper than a single cab pickup tipper?
Many other suggestions?
Thanks in advance, more questions will probably follow
13 minutes ago, Andyk said:
Hi all,
Courses are self explanatory but you’d be better working for someone else PT and yourself PT to build up your experience, reputation and workflow. When working for yourself know your limits.
Yes you’ll need it most days even if you plan on hedgecutting. It also gives you a package to offer other firms ie tipper chipper and 2 men for £xyz
Vehicles are different for everyone but the smaller the chip box the more time is spent tipping off and not on the job I have a 3.5 ton van with 1.2 ton pay load and a small van for quoting and knocking around in, May have to swap that soon for a 4x4.
Find what works for you and grow change your kit to suit your needs. Don’t be afraid to do other things I.e subby your services, hedge cutting and maybe a bit of maintenance if you can get it as initially you won’t have the reputation to do picture perfect trees everyday and advertising will only get you so much.
Good luck I wish you well.
Thanks WesD
I've got a couple of people I can work with and plan on offering other services. All food for thought.
59 minutes ago, eggsarascal said:
Give it a miss, you need experience in what you do before you go it alone, then it can still be hard going.
How will I get experience if I give it a miss??
1 minute ago, Andyk said:
Thanks WesD
You'll gain experience by working for a company, wether that be a small crew or a big outfit. Rushing in starting your own firm with no 'hands on' experience is for the brave, or stupid.
I think a bit of tree knowledge would be more valuable than saw tickets if you want to go it alone. Imagine pricing and you couldn't name the trees, or suggest how and when to prune, or what would be best for the tree, and better for the client in the years to come. Tree knowledge and biology is very important and learning how and why to prune properly. Good luck ?
I'm not sure which one of those you think I am?
...but you are right, far better to gain experience at someone else's expense and if the experienced crew don't succeed in making you avoid breakages at least the boss pays.
Pretty good with general tree knowledge and ID. I currently work at nursery specialising in specimen trees and shrubs with a “architectural” nature, natural and trained. It also gives me a place for queries and to dump all the rubbish.
I should add I’m not planning on going straight into it. I intend on going part time for a year or so in my current job and going from there
It think you are a smart fella. Gamble, go for it, but if you get it wrong you're on your own to get it sorted.
