Tractor front ballast?
richy_B
Anyone got a good idea of front ballast calculations?  I am trying to work it out for my Same Dorado 86 but it is making my head hurt!
 20190128_190653.thumb.jpg.d0bdb94f38c8d069b00acac0f6f0a54f.jpg20190128_190723.thumb.jpg.fc88af2b46856f5d8f5c6c56c5e216c3.jpg20190128_190713.thumb.jpg.8803ed8ce08b1b962fe1a6dc6879bdce.jpg
I have got these as :
T L 3220
T V 1490
T H 1730
G H 900
G V
a 800
b 2185
c 774
d
600
I have tried it a dozen times and cannot get anything that resembles a feasible number.
Edited by richy_B
The manual states the front axle much have at least 20% of the unladen vehicle tractor weight ( so 20% of 3220kg = 644kg ).
The weight distribution unladen is 46% on the front 54% on the rear. This is 1470kg front and 1730kg rear).
From the middle of the front weight to the centre of the rear axle is 2985mm. From the centre of the rear axle to the middle of the flail (which I am trying to ballast) is 1374.  So 70% distance ahead of the rear axle and 30% behind. So roughly the front ballast needs to be the rear implement / 2.35. A 1000kg implement would need a 430kg weight to maintain the 46/54% weight distribution.
The maximum front ballast is 320kg but I assume based on the I have 826kg weight within the tractor (1470kg unladen front axle minus the 644 minimum).   So I wouldn't need to use the all of them to achieve the minimum 20% but if I did put all 320kg I would end up with roughly 39% to 61% weight distribution.
Do this make any sense to anyone???
Edited by richy_B
Haven’t given it a moments thought if I’m honest, if the implement is 1000kg plus, then I keep 200kg of weights on the front. Feels safe and stable.
think of the leverage of a loader with 300kg bucket etc, keeping 320kg of weights on the front is considerably less stress on front axle- I assume that’s what your worried about?
The handling on rough stuff is my favourite bit about the dorado so I was trying to work out how to maintain this really. Saw there was a formula so thought I'd give it a try.
I'm going to go with roughly a third front ballast of the rear implement. I don't have anything over a ton so should be fine.
Appreciate the input guys.
Edited by richy_B
