Double choking a cambium saver is fine if it is long enough to do so. Not sure what you mean by using two cambium savers though. Do you mean joined somehow to increase the length? If so I wouldn't, as there are plenty on the market that are fit for that purpose.
Thats what I meant/do.
Also use a short length of rope adapted for the same purpose,maybe I should look at a different system,by the time most of my work gets big diameter I can go for a fell,or,as I prefer use the mewp.:blushing::001_smile:
  • Replies 24
  • 2 months later...
Got a chance the otherday to try both and for me I like the sport tryed it whith 13mm rope just wondered if it works the same with 11 mm rope and can you buy it ready for the 11 mm rope I climb on aris if this helps any help would be great cheers
Lockjack hands down for me. Once you wear it in it's so user friendly. Being able to adjust your position from above it is so cool!
Edited by Dan Curtis
Spelling
