Having just moved my woodpile to a new site on the farm,I've discovered that I've managed to pick the boggiest spot,unforseen rabbit development ! already stacked several cord to season and got alot more to add - so I thought about adding a strip of hardcore to make life easier.
Looking to put in a strip of 4m x 30m - so thinking of about 30tons of clean hardcore - not crossing the planning bridge quite yet,it's got to take a landrover and 2 ton Ifor at times
How would you go about this,dig out and infill - with or without membrane or just plonk it on top and compact down to where I want it,personally thinking this may be best,leaving the harcore level just below that top of the pallet that the woods stacked on.
Cheers
Steve
  • Replies 24
my thought excatly !! my day today could have done with 30 tons of hardcore , i knew the ground was gona be soggy but i can honestly say for the first time ! i actually got my landy stuck :thumbdown:spent and hour laying old shed panels down then finally got out ! unfortunatly by the time i got out , my mate had tried to get in ,in his transit !ha :confused1: and well you can guess how that went ! finally the tractor was called for , :thumbup:
so i share your thoughts right now ! hope you get it sorted
Cheers
Steve
put some crushed brick down 1,st ,then top it of with road planning to get it nice & leval :thumbup:
Just on the southern edge of Ashdown Forest,must be where all the run off's coming from!!
It's wet wet wet nearly got stuck on Saturday without a load on !
if its that wet its worth getting the soft stuff scrapped off 1,st .& putting some mamebrain down if your going to be there long term :001_smile:
Not used crushed brick before - how does it compare to clean hardcore cost in bulk - I'm looking at just over £100 for a 10 ton load,do most aggregate suppliers do it ?
Cheers
Steve
must be running down to herstmonceux as well !! :001_smile:
I think you might want more than 30 ton.
I have just done a track & used 70 ton for a 3m wide & about 50m long track & really it needs more. I used "sub base" which packs down hard.
