1 minute ago, Ambisawrous said:
My point is you could have 7m trailer box and then have a legally lit projection beyond this. Yes 8 man boats are 18m long and are two piece bolted together. In USA they cart them around in one piece, the trailers are huge!
I used to be of the same opinion re the overhang.
After finding a new official doc recently I am now of the opinion that the over hang is counted in the max length.
3 minutes ago, Justme said:
I looked on the website but its not listed.
The standard length is 3.1m
The OP is wanting nearer 7m.
Most would trailer it small & then site it & add the extension.
The Woodlander XL is closer to 5m.
The website says 770kg for standard length, no fuel or cutting fluid so would possibly be ok if you didn’t mind removing something more than 20kg and carried fuel and water in the truck. I’d want it over a weigh bridge though to be sure.
Mines 22’ track so definitely over.
Never known a mobile miller remove the mill from the trailer, add bits to it and set up on the floor.
Where did you find that? Looked everywhere!
Im now torn between the Hm130 XL and the new Logosol B751, which looks the absalute dogs and has a lot of add on features coming out soon. But no Trailer. :/
So what do you do with yours as its over 750kg then?
Wonder why the weight is not mentioned anywhere? Neither is Norwoods.
It’s on the website in tech specs
