1 minute ago, Justme said:
Maximum Legally Permitted Mass.
Similar to MAM for vehicles.
The most it could be inc all loads.
A trailer 7m long will be close to that to be stiff enough to be used as a milling bed.
Cheers. :)
I think the key word is close. :D
As well as farming I also sell racing rowing boats, these are long, we tow 13.6m boats behind double cab. The boats do project over the top of the pickup and also to the rear of the main trailer box, this has an extendable lighting board so this basically extends the length of the trailer whilst remaining legal. You could see if these guys will sell you just the chassis with the main box or boat racking
https://www.degraafftrailers.co.uk/rowing-boat-trailers-1
1 minute ago, trigger_andy said:
Cheers. :)
For the trailer, add the mill & your over.
If I was designing this, I doubt I would try to plan to be under a total all up weight of 750kg.
I would also want the trailer to carry the kit needed, fuels, spares ect.
Again at 7m I would want twin axles.
Yes an exemption for an indivisible load.
Boats cut in half dont generally work well.
( I have seen bolt together long boats with a strong bulkhead to bolt the sections together)
A bolted together mill has no such need.
Would be good to get an official number.
Ive not heard of a single person in Europe or the US having issue with the Norwood or Woodland Mills Trailer having a single axle.
I have plenty space in the back of my Jeep for spares and Fuel.
If it’s going to be a tonne or under no real need for twin axles, I’ve been towing boats all round the country for nearly 15yrs on single axle trailer 10’s of 1000’s of miles never had problem. If you have to man handle it in a tight space you will be very glad of a single axle, it will turn on itself.
My point is you could have 7m trailer box and then have a legally lit projection beyond this. Yes 8 man boats are 18m long and are two piece bolted together. In USA they cart them around in one piece, the trailers are huge!
I looked on the website but its not listed.
The standard length is 3.1m
The OP is wanting nearer 7m.
Most would trailer it small & then site it & add the extension.
