Husqvarna 350 carburetor adjusting
goosemasterkl
I need some advice from some experienced timber cutters; I'm working on a Husqvarna 350 chainsaw and I have the carburetor adjusted where it has good quick trigger response, good top end rpm's but when I try to cut a log with it it wants to bog down and becomes practically useless unless you baby it thru the log. How and what jet needs to be adjusted different to where it will cut thru the log like it's suppose to? Any suggestions would surely be appreciated. Thanks in advance to anyone who replies.
If the carb has no limiter caps, turn both screws in lightly and then out just over one turn on both screws and then adjust the idle. If the saw is in good order, it should cut pretty well. It may be that your saw has other issues and that is why it is bogging.
These saws have a strange engine in so much that the lower part is made of engineering plastic and can warp causing air leaks that then can take the top end out - seen a few now.
See where these settings take you and if it is screaming on the top end, open the H screw until the saw flubs and smokes and then turn the screw in until the top end cleans up to nearly clean but with a hint of flubbing or four stroking.
Flubbing is what I call "Four stroking", if you rev a two stroke and richen it up whilst running, the revs start to reduce and the saw makes a pulsing flub, flub, flub sound known as four stroking. The extra fuel is actually stopping the saw firing every stroke so it sounds and fires like a four stroke. This phenomena is used as a rev limiter for the engine which is why adjusting the H screw correctly is so important.
If your saw wont start on 1 turn, it may have issues such as chip in the gauze filter, split fuel line or an air leak......or just have a carb that runs a little lean.
I thought it was " Bill and Ben " speak ....
