Ticking Hilux!
Mull
They are quite noisey on injectors in general, but if you feel it is abnormally loud then it could be in need of a new (or more than one injector) injector seats can fail too, allowing combustion pressures to leak causing the sound when engine is under load, i.e acceleration.
They are quite noisey on injectors in general, but if you feel it is abnormally loud then could it could be in need of a new (or more than one injector) injector seats can fail too, allowing combustion pressures to leak causing the sound when engine is under load, i.e acceleration.
Aye this is the kind of stuff I’ve been coming across@Ratman , truck performs really well, I believe in America they call it the “ Tacoma tick”.
Suggesting it’s part and parcel!
