Currently supplying 2 large pubs with logs and also going to add more with people's houses. Currently split around 400 8-9inch rings in 3hrs with splitting axe.
whats the next cost effective step up? Or just work faster!!?
One pub has gone through 3T in just over a month and it's not even cold yet!!
regards
7 minutes ago, Steve Bullman said:
Processor!  You'll do the the work in half a time without breaking a sweat and never look back.
How much are they?? I've no access to a Mog with PTO etc. How good are the hand powered farm jack ones around 10-12T???
No idea on what kind of wood you are splitting, but if it's big(over 2ft dia) maybe have a look at a petrol driven log splitter.
If it's fairly straight stuff around 15" dia it might be worth hiring in a processor.
I've a WP36 that runs off either it's own engine or a PTO and when I hire it out I expect it to process around 25-30 bulk bags of soft wood/ day or 20-25  bulk bags of hardwood, slightly less than the softwood because misshapen bits take a little longer.  £300 is normal for a day's hire + operator.
£8k buys you a used mobile WP36.  Maintenance costs are very low and running costs are roughly £25/day for petrol
Not sure what prices are like in your area, but most selling firewood now don't talk about price per ton.  It's either by a measured trailer load (m3) or bulk bag.   If you can find a market for around 200 bulk bags/year you would be well advised to invest in a processor.
Cheers for your help mate. It's mainly ash, oak and Beech. 8-9inch rings  I think I'd be best to see what my actual demand is for this year and see what client base I can build first?? Then move to a processor once it's proved to be a viable option. I'd rather buy then rent on a personal choice.
Edited by Lust4life
Info error
Processors are the most efficient but a big step up and if you're happy with a chainsaw and axe and do mostly arb waste (guessing from the fact you said rings) you would be hard pressed to justify one for small quantities.
If it's less than a hundred ton I would get a horizontal petrol splitter and put a log table on the end, both at waist height so you can resplit without bending down then slide the wood into a bag or container.
You could just prep a load of rings and then hire in a man with a petrol splitter for probably about £200 for the day and split the whole lot. Just do that every time you've built up enough enough to justify, will save you hours of your life.
It all depends on your supply of wood I started with a processor a basic second hand jappa 700 which would be fine for 8-9inch . How ever things change I used to buy in cord but have now found it harder to come by and more expensive . I have now also got a 20 ton horizontal splitter which would do billets as well as rings as I split more arb waste than anything else . I think an ideal set up for you would be a splitter which would do big  rings and make billets of the straighter smaller dia stuff  season the billets then cross cut with a rocking table saw I process 60-80 ton a year as a spare time thing
I was in the same situation a couple of years ago.... You spend all the time splitting with an axe then stacking then moving..... I then progressed to a 14t petrol splitter and then last year realised it still takes forever.
I can't buy straight lengths in as it leaves min profit and most of the wood I come by is ARB waste so I decided to build my own processor.
I got a large single axle trailer, an old twin cylinder Lister diesel engine, a 30 inch tct blade,and a couple of rams and a pump..... Lots of head scratching lots of welder burns but now my processer lives and cuts me a couple of  hundred tonnes a year....
All in it has cost me about 1k to build and it's how I wanted it and in the way I do things.... It won't win any beauty contest but it works and is safe and cuts all the logs I need.
Since having the processor done it works out that what I used to cut and split in a month can be done in just over a week....
Edited by Taff855
