3 minutes ago, Ratman said:
Can you not go to s plumbers merchants and ask for some 60mm solvent weld? May possibly be grey in colour emoji848.png
I've got stacks of solvent weld, but I doubt it would withstand the heat so close to the heater. I asked Vesp, sorry I meant watched YouTube, where someone tried the same with a Y piece and it melted it.
Can you devise a tin heat shield to keep it away from heat?
16 minutes ago, Squaredy said:
Exhaust pipe?  I would guess some of it is 60mm so you may be able to scrounge some from a scrap bin at an exhaust place?
It's something to look into. I can't believe that I can't find the name of the material used in the pre made T/Y pieces.
