I picked up a 262xp a while ago. The bar's some sort of Oregon replaceable nose, 18" and the 3/8" chain on it has 64 drive links. I want to order more chain, plus a loop of ripping chain which will also be used on a 390xp with 18" bar. The only thing is, everything else (262xp owner's manual, owner of the 390xp) is telling me that I need a loop with 68 links, not 64 like the one fitted to my 262xp. Even my 357xp manual says 68 links on an 18" bar for 3/8" chain. Any ideas which one I need?
Clue: the bar I have has been hacked at the powerhead end, with oil holes drilled out into slots etc.:confused1:.makes me think this bar has been bodged to fit.
bar length is a funny old thing...
oregon make a number of different 18" bars and they are all a slightly different length. i have a few 18" small mount husky bars(262xp size) ranging from about 16 1/2"-18 1/25"... the 18"ers oregon make for dolmar tend to be shorter than the husky ones...
or yours could have been cut down, it should be pretty obvious, post a pic if youre not sure
buy a stihl
thats just sooo funny it gets me every time........
Me too mate- if i hadnt been wearing a corset my sides would have split....:001_rolleyes:
Still, i'm sure it helped the original question get answered.:sneaky2:
quickthorn- i mis-read your post, if you know the bar has been shortened then, thats why it takes a few links less, it would originally have been a modern 68link powermatch bar. possibly modded to allow the use of a bigger 9pin sprocket:confused1:
This is the best picture I can take with the camera i've got. Although you can't see much, there seem to be 2 sets of tension adjuster pin holes. I don't know if that's normal on Oregon bars (never seen it before), but the ones on the right look bodged; the oil hole at the bottom looks like it's been altered with a hand held drill and twist drill..the picture doesn't really show what a mess it is.
I'm wondering if this bar's meant for a Stihl, and it's been hacked to fit the 262.
Whats the part no. embossed on the bar Quickthorn?
I have an 18" power match bar in 3/8 and it needs 68 DL.
An 18" Pro lite bar uses 64 DL
Power match are the replaceable nose type. :001_smile:
we've got "7719", then "1858 134OUJ"; the last one's probably the part number. It is a power match replaceable nose bar.
Looking again, if the tensioner pin went into the back hole, a 68 link loop would probably fit. I wonder if someone before me drilled extra holes to get their 64 link loops to fit??:confused1:
