So, we were having a discussion about replacing a telehandler with a digger that has similar reach and lifting capacity. 6m min and a ton at full extension. Would need a tilt on it and pallet forks etc
i think it would be a more flexible tool than a straight telehandler. For example exact placement of pallet loads without shunting about.
help loading out block and beam , loading out scaff with blocks/bricks etc
unloading lorries.
pro’s
multi use
faster work rate
cons
not as much reach
 can’t use on road
slower loading - maybe
so my question (Eddie!) what would be the smallest footprint digger that could do this, what make / model . We will be replacing a telehandler next year but if I can sell the pro outweighing the cons It could work.
budget 25-30k + vat
You've covered most of the key points, I would say a digger could also damage the yards more and might be too high for sheds but will be more flexible with a grab and can reach up and over into trailers etc.
I would think you're looking at an 8ton digger with 4000+ hours on your budget. 13tonners are easier to find but might be too big.
I do like the jcb hydradig with the double knuckle setup. Wonder what they like on the mud.
being able to drive it on the road is a major plus.
8 ton is going to struggle with a ton at full reach. 10 ton plus to be the boss of it. Although flat yard swings in its favour. Also the pallet forks if facing out will shift the load further out then equivalent load in a bucket.
You know your yard so you know what will work- a telehandler will be quicker moving loads over any distance. Digger better if your sitting in one place and swinging loads say off a lorry and placing behind you etc.
I think you may find the digger a bit restricted if working in a tight area. Quite hard to get the pallet forks to work close into the machine due to the geometry of the bucket tilt.
I should have mentioned it will he only used on building sites. Maybe with a crane boom attachment it would have the height to lift trusses on.
from my rudimentary research I think the English market is not going to have any so which euro country will be best ? Germany?
also I think will need to up the budget a bit.
It’ll not need a crane boom on the average Rotating Telehandler and often they come with the additional crane winch and man basket.
Plenty in the UK
Eddie.
