cricket bat willow wanted
Badgerland
Afternoon all.
As title says, I'm after a small quantity of clean cricket bat willow for basket making. 5 foot lengths are ideal but will consider others. Diameter can be between 12 to 20 inch.
As I say, not a huge amount needed so not looking for a lorry load!
Anybody out there got anything suitable?
I'm based mid wilts - 7 miles from Devizes.
22 minutes ago, Badgerland said:
Afternoon all.
Please excuse my ignorance but why is cricket bat willow essential?  Just curious and nosey!
Hi there Squaredy.
Cricket bat willow isn't essential, but it is one of the better woods I've tried. I make a form of basket based on the old Devon splint baskets. (Have a look on my website www.greenmanwoodcrafts.co.uk) The problem with the originals were that by today's standards they're very heavy. In the past they'd have used them like buckets, ie put it on the ground then fill it. When you're good to go, pick it up and move it. Nowadays people want a basket that they can carry around more. So weight becomes an issue.
Believe it or not, I've found Wellingtonia is not a bad substitute, but it does suffer from being rather soft whilst at the same time very brittle. Weight wise though it's spot on. (And you get one hell of a lot of it out of one tree!)
Cricket bat willow is light, tough and flexible enough to make it easier to put the baskets together. Although I have found it a bit of a bugger to machine down to about 5 mm without it tearing.
20 minutes ago, Badgerland said:
Hi there Squaredy.
Thank you that is interesting.  Thank goodness for cricket.  Looks like you will get your willow.  I guess you have tried Alder and Poplar?  Black Poplar is meant to be very resistant to abrasion.  I will browse your website with interest.
I couldn't possibly comment on cricket! (Well maybe suffice to say it's morris dancing without the bells!)
No, not tried either Alder or Poplar. I've got some alder in the drying shed but it's so hard that I don't think I'd get the flex I need when making up the baskets. Although I do like the finish. Have used Poplar before for various other projects which were eventually treated with a coloured preservative, but as a bare wood, if I'm honest, I don't like the look of it. I've tried tulip as well but that suffers from the same issue.
You scoundrel.....say what you will about Poplar, but do not sully cricket......
Alder was used for clogs, so I am guessing it has some flexibility, and it is fairly soft.  I like lots of the products on your website by the way, very nice.
