Ha,  I feels a bit like it. Going to have a go at the EGR on the weekend.  The intermittent nature of the fault is the worse bit.  I can do 10 X 33 mile journeys with a quick check of the coolant before I set off every time and its absolutely fine. Then out of nowhere the coolant shoots out like a fire hose.
There seems to be absolutely no oil/coolant mixing at all. I drained the oil (which i only put in a few weeks ago) and its looks fine. Equally the coolant exiting doesn't appear to have any oily residue. I am thinking its exhaust gases that are getting into the coolant system but the head passed compression and chemical tests so what else is there but the EGR cooler?
  • 3 years later...
