New thermostat fitted, made no difference.
Pressure test was fine, so taking the radiator off to get a new core
Pressure test cold and hot?
When you say its pressurising, does it happen before the engines up to temp or once the engines up and past running temp?
Something else to check after all the above:
Water pump impeller. Sometimes the vanes are non existent if the motor has been run without antifreeze in the past. I’ve even seen the shaft sheared off internally. The pulley still giving the appearance that the pump is still working
