  On 24/08/2018 at 21:44, openspaceman said:
Why was this removed? Thermostats  can both open the path to the radiator and simultaneously block the bypass used for quick warm up
Expand
Yes I've heard that before, so ordered a new thermostat.
I removed it, hoping/thinking the engine would run cooler without it. It has made no difference
Expand
Then I suspect the radiator needs a more thorough clean especially if  it has had any radweld type gunk or a mixture of blue and pink antifreeze.
Pressurise the system manually using a tester, cold to start with, if pressure drops over a short period of time then your in to the obvious..... theres a leak, check visually first for any external signs i.e hoses, head gasket area, water pump gland, water temp sensor body, the usual etc.....
If no signs then you could be looking at an internal leak, possibly on inlet/exhaust side through a fractured head as husk king suggested earlier. If no pressure drop when cold then it would suggest that you have a internal fault once hot.
So run engine up to temperature, watch your exhaust for signs of grey/white smoke whilst doing this which would also suggest water/coolant loss, and repeat pressure check again?
But if you are having to get to this point then chances are your looking at fractured head or porous liners.
Did you see any pitting on top of block or fretting marks around top of cylinders near where fire ring sits on head gasket? Did you have head faced/skimmed and pressure tested whilst you were changing head gasket?
Read more
