Hallo,
I've decided my life is void of meaning unless I have a lathe.
I've played with turning before, a long time ago though, and am a complete novice, I know very little about what machines are good and what just looks good etc.
I'm looking for a machine that's easy enough to use for a beginner, but doesn't need upgrading too soon because of reaching the limits of capability?
With such kit, is it better to buy a really good solid 2nd hand or new?
What's a good selection of chucks etc to start of with, wanting to turn bowls, small plates etc.?
Basically: help, I'm clueless!
Thanks, Daniel
welcome to the weird world of turning mate.
the machine you want depends on what exactly you would like to turn.
a good second hand one to start you off is the best way to go.
i'm on my third lathe and have had it for ten years.
Well... I don't don't really know exactly what I would like to turn...
I would like to make some bowls, tool handles, small trinkets etc.
Is there a machine that'll do most things ok? I suppose if I want to specialise in one thing or another I can get a machine to suit the specific purpose, but until I've tried everything a bit I won't know?
most lates will be able to turn those sorts of things the only limit being their overall capacity and power so i suggest you buy a small but decent lathe off ebay and have some fun till you discover what road you wish to go down.
i'll see if i can find a few for you to look at.
what is your location?
Edited by se7enthdevil
Maybe consider a shopsmith? not for everyone but a very versatile little machine, good lathe with a few other bits added on! Got myself one two years ago.. must admit I rarely use it but thats my fault, not the machines.. check them out.. expensive new but can be got secondhand now and then. Mines a mk5 from the late 80's. built like a tank and still in good nick.. Basically its one motor running a drill, lathe, sander, band saw and circular saw in one. Any lathe can only be as good as the chisels you're using on it.. so spending a few quid on those is equally important!
As far as I am concerned a well built older machine is a better buy than a flimsy cheapo new one.
Thats my two cent.. if you are serious about turning bowls it may be better to go for a dedicated machine.
9 hours ago, se7enthdevil said:
older is usually better i agree but i would not go for a shopsmith if you only want a lathe.
what's your budget dan?
I would tend to agree to be honest, however if you need some other tools to compliment the lathe it may be a worthwhile coonsideration.. if you have a few bits in the workshop already, probably cheaper and easier to find a good old lathe somewhere..
Got an old Coronet No 3 myself. Does all you have mentioned and built to last so worth keeping an eye out for SH IMO
Like this with a rotating headstock which enables large bowls to be turned.
https://www.ebay.co.uk/itm/record-power-woodturning-lathe-coronet-no3-with-many-extras-IE-chisel-blanks/332771408006?hash=item4d7ab8b886:g:WBgAAOSwkzhbeb~5
Edited by Woodworks
