Peter's Truck Thread
Peter
  • Replies 211
This looks pretty ideal - great job Peter. I think it makes a lot of sense having a rear mounted crane. When I've looked at big side tippers in the past I see they often have sides hinged at the bottom that act like a chute, I guess to keep the material away from the truck. Do you have any trouble with pieces of timber or chip piling up against the truck when tipping?
Cheers, Sandy
I debated that one for ages, in the end I went with 1 piece sides because they are easier to remove and replace, and I don't need a standard drop side body, it's either a flat with bolsters or a big chip box.
I mostly tip to the passenger side, which is almost completely tool lockers so they hold the chip back, then once it's tipped I lock the steering over and reverse out. I never tip logs, everything is in lengths and unloaded with the crane.
How exactly would a tail lift work with a rear mount crane stephen? Or do you mean transport it on the lift like you used to with your GM chipper? It's impracticable for towing a trailer and would just add unnecessary weight. I do have a divider to make a space at the front of the chip box where the mini loader goes, even with that on I still have 16 cubic metre capacity.
