Hs81t clutch drum and drive pinion removal
jjll
20 minutes ago, jjll said:
Hi
Trying to get the clutch drum and drive pinion off a hs81t
I have removed the circlip and am struggling to get the pinion and clutch drum out.
Are they threaded or will they press out?
I replaced the bearing on an 81r last week, there are two circlips, a smaller one and a larger one. Took a bit ok knocking with a socket to get bearing out ?
Pinion on the 81T (trimmer) screws onto the drum if I remember correctly.  While the 81R (cutter) is a one piece drum - gear which is a press fit in the bearing with a circlip holding it in place.  And obviously another circlip holding the bearing into the housing.
I've rebuilt loads of 81R's, but can't remember the last time I stripped a 81T, so sorry can't be much more help.
