I have converted to led indicators and the adjustable wipac relay keeps breaking. In the six weeks since i have converted i have gone through three relays
Had anyone had similar issues, and what have you done to resolve it.
Cheers
P.S. i have a repeater set of upper lights on the back, so i have six indicators in total.
  • 1 month later...
Yes we had problems and went back to normal lights on our Defender tipper,as i remember it was
somthing to do with running the non led repeaters with the new led lights and the green flasher bulb in the instrument panel ....they dont work together... i do belive you can get the parts needed from Paddocks
Good luck with that one
You need one of these Mr Girdle https://www.ebay.co.uk/itm/Smart-universal-fitting-7-way-bypass-relay-TEB7AS-Towbar-Towing-canbus-wiring/321086115886?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D53343%26meid%3D5d50d57b831b426c82276dfcdcf6a569%26pid%3D100005%26rk%3D5%26rkt%3D12%26mehot%3Dpp%26sd%3D163183785379%26itm%3D321086115886&_trksid=p2047675.c100005.m1851
Run another fused power source to it and connect it onto the rear wiring harness , everything non led on the vehicle including the towbar wire into this unit. It basically just senses voltage and switches the relevant circuit taking its power from the other source. Your led relay wont know its there.
Bob
Edited by aspenarb
We have possibly narrowed the problem to the shared indicator light on the dash. I have now split the circuits and have two flashers on the dash on each indicator. So far so good
Bob
I will give that a go Bob if the current fix doesn't work.
