Does anyone know the implications and what to do to change front mounted close couple pto chipper to standard rear mounted tractor.Is it a matter of changing the linkage set up,or is pto in reverse direction?Any tips cheers
Yes it runs the other way.
Which chipper is it??
Front mounts are fairly uncommon and so hold there money, standard rear PTO machines tend to be much cheaper, I would sell the front mount and buy a standard PTO chipper.
if its a schiesling then just bypass the reverser and run a shaft from the tractor straight to the fly wheel, all the chipper has is an extra shaft running to the reverser then back up onto the standard pto adapter. you will need a bit welding and grinding, but you could easily make it adaptable to front and back with the same machine. or i can sell you either lol
spot on mate :biggrin:
i tell you it fairly makes the ride smother by mounting front imploments. wish id done it years ago :laugh1:
