The wiring was a bit dodgy on mine, glow plug only worked occasionally, just used to put a wire from the battery positive straight in to the plug for 5 seconds and it worked fine!
Just dropped it in for mechanic to have a quick look check things like that.
Any pointers to manuals or people that may be able to help?
  • 3 weeks later...
On 30/06/2018 at 22:02, benedmonds said:
I don't think our antistress ever worked, not for long.. Pretty sure someone on here told me a way of resetting it. It would work for a while then not..
I have a vague memory that there way a pin that you pulled out that stopped the hopper lifting up..
Please tell me more about that chute extension. I have noticed mine seems to have a pretty glorious scatter fire on the chip. Thanks
It was always a messy chipper. Used to leave a pile underneath as well..
The extension helped, just attached some folded sheet metal..
1 hour ago, billpierce said:
My engine says 625 on it is the only Id I can see
Is that on the plate shown on P14 of the PDF I posted? That no. doesn't ring a bell (but We've had 2-3 new engines in that machine over the years, I think there was a GM with a Lombardini at some point and the ST6 is also a Lombardini, so I might be getting confused myself.
