8 hours ago, Stere said:
Nice the ego stuff looks decent can't find specs for the motor in that model?
There top one is carbon fibre shaft and 2kw motor, looks as good as the the top battery stihl or husky stuff probably better...
Carbon fibre tubes are pretty cheap makes sense for the shafts material dunno why its not used more?
Find many great new & used options and get the best deals for Carbon Fiber Tube From 5mm up to 20mm(Roll...
I looked at that one. Down side was you needed the back pack n=battery or battery back pack adapter to sue standard bats. That added nearly £200 to the set up costs. The 3800 is supposed to have the same 2kw motor.
We will see IF it ever arrives.
Cant see me recommending the company I got it from.
Well eventually the brushcutter & mower arrived BUT I had to wait another week & a half for the battery & charger.
The brushcutter is great. I have used it of rough knee high thick grass, brambles (fresh & old), raspberry canes (fresh & old) with the line trimmer & the metal 3 blade attachment. The 3 blade really kicks ass & seems to use less battery life. Its great for virtually mulching very over grown areas. So far the 56v 5ah bat seems to last about 20-30 mins of solid use dep on what I am doing. It then takes about 45 mins to charge inc cool down cycle. Once I have the area under control I expect usage to go up to match recharge time. Two 5ah bat should keep you going all day.
I also used the mower a little mainly as a hoover in the grass area. No real usage stats as the use was hardly typical. Filled the catcher twice for about half the bat using the drive motors as well as the cutter.
