1 hour ago, tree-fancier123 said:
it doesnt look great where the rope passes near the gate - not generally sharp edges, but still a risk
if you've forgotten your wrench, maybe you still have a figure 8 descender in your bag, better than nothing
You can just move the tail over to the other side of the crab. Better than a f8 as no twist too. Reduces the load plenty to make the hitch work correctly.
As Steve said, similar to the system Kevin Bingham was using before the wrench but no extra hardware required.
  • 3 weeks later...
Fairly sure you’ll be wanting to put the friction above the hitch. I have seen a set up with an o ring above the hitch, with a short tether connected to the hitch climber. And run the rope through the same way as you have here.
