This needs to go to a good home.Β Β
Due to commercial pressures it must leave site tomorrow but there will be an Avant there that can load it.
There are at least 12' of straight single stem with probably another 2' before it bifurcates.Β  Diameter 14-18".
Β
Any takers?
Hello Hopalong; how's it going?!
Β
Yeah, I'm sure I can keep the stick somewhere safe for you.Β  What lengths would you want it?Β  It will have to be cut for transport.
Β
Jon
Result - the stick's going to the Wilts/Dorset borders for Gobby to work his magic on and the lesser sized material will go for firewood so even Huck will be happy!Β :D
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
