For small stuff the Bilke takes some beating, IME the secret is running it slowly with a big tractor. Doing this you get pretty decent looking, uniform logs.
The mistake most people make is running it at speed, because the tractor is too small, this just produces a pile of smashed up crap.
I must say the bilke is a pretty unique machine, when you say big tractor.... how big we talking ? have u tried the electrical version ?
I use my Unimog which is over 200HP, I just run it at a whisker over tickover.
I'm not sure what the minimum HP would be needed for decent logs, but a David Brown 885, which is around 40HP, is far to small. It will run it, but needs to be at fairly high rev's, so the wood is smashed to bits.
I would guess that 100HP+ would be enough.
You need the perfect wood for those machines.  Its an impressive tool to watch working though although quite expensive I thoughts.
I went for a japa in the end.  Takes me about 1 hour and a half to make a 3 cube load in my transit
Not sure what you mean by "the perfect wood"?
I simply put all my small timber through mine, mostly branch wood, sure it can't be too bent, but small bends are fine and I simply cut very bent stuff in half. Its by far the fasted way of processing small timber, IMO.
If your processing timber of all shapes and sizes its best to have a selection of machines.
