Which saw mill would you recommend , I have been recommended panther .
I’m looking to get my self an Alaskan mill for my Husqvarna 395 . I’ve been recommended  a Panther mill with a 42" lo pro bar which comes set up with a winch . It’s priced at 495:00 with vat . Can anyone recommend a mill that may be better than this ?
I've only used granberg so I can't compare but I would say the ratchet system for adjustment looks very handy on the panther. Rob D will be able to advise you how they compare If the build quality is good they certainly look decent.
  • 1 month later...
I'm going to be biased on the Panther mill ;)seeing as was myself who helped guide the design... all I can say is the aim for the Panther mill is to be the best and most advanced chainsaw mill in the world. Not doubt this won't happen overnight - but that the the aim :)
Height adjustment is tool less and fast – in fact it is the fastest compared with any other mill on the market. Simply rotate the round handle to adjust how deep the mill will cut. No need to hold a spanner in one hand while trying to adjust the mill with the other.
'Attachment is the quickest of any chainsaw mill – easily bolt and unbolt your mill to your chainsaw.
Attachment to the saw is bolted not clamped – the saw can never slip in the mill.
The mill is designed to be used with special GB Lo Pro milling bars which are thinner and narrower than existing chainsaw bars for a faster, cleaner cut.
Panther Mills automatically come with a full winch set up to make milling 80% easier than pushing by hand.
There is a dedicated Panther First Cut System to ensure your first cut is table top flat. This first cut system can be extended and widened indefinitely.'
  • 3 months later...
Looking to buy a mill to suit my Stihl 660. Already have 30 and 36" Stihl bar with the saw.
I would welcome any advice on which is the very best mill to buy, which attachments and what chain is best.
Not forgetting where to buy.
Thanks in anticipation.
One with a built in winch and a set of jockey wheels on the saw side.
42" sugi hara sprocket nosed bar,
And granberg ripping chain,
An 8 tooth sprocket for medium diameter wood is fun. [emoji3]
All available from rob d.
[emoji106][emoji106][emoji106]
Agreed - Panther 42 looks like the best option by far - however comes with different bar and chain than you suggested.
